SOLD: '06 Marz Z1 FR Fork 2006 model Z1 FR with 150mm of slick Marzocchi travel for sale. - SOLD!! The fork is in great condition and was serviced by Garageworks (Irvine) a while back. Superficial scratch on the right stanchion (does not effect performance at all), maybe a few scratches on the lowers (typical wear). No leaks. DAMPING SYSTEM New Hydraulic Compression & Rebound Damping RC2 Open Bath Lubrication ADJUSTABILITY External Positive & Negative Air Preload (Doppio Air) RC2 System for Compression (Bottom) & Rebound (Top) Progressive Air Bottom Out SPRING TYPE New Redesigned Doppio Air System (Positive/Negative) TRAVEL 130mm to 150mm (One Cartridge w/ Different Pressure on Negative Chamber) TOP CROWN N/A LOWER CROWN Forged FR Crown w/ Cryofit "M" Design ARCH/SLIDERS Magnesium FR Monolite One Piece Arch & Sliders STANCHIONS (inner legs) 32mm Alloy Tapered Tubes STEER TUBE Alloy FR Steer Tube DISC BRAKE MOUNT Disc Brake INTL STD DROP-OUT TYPE NEW 20mm Drop-Outs Through Axle The steerer tube is cut to 8in. so it should fit most bikes. Star nut included. I will ship for $15, local (Orange County) pick-up/drop off preferred. PM me with questions.
Already on MTBR as well... Somebody NEEDS a 150mm fork for their low cost project, I just know it... :bang:
I do need one for my mongoose but im a little bit short. paying mortgage and car at the same date #-o lay away? :-k:?::bang: if you still have it in two weeks, just maybe.
